Those with ported lt1 heads and hooker lt's
Which header gaskets are you using? Looking for best fitment and sealing.
felpro 1406 i believe and ultra copper sealant :cool:
1406's look like they will block airflow, anybody using any different? Are there any gaskets out there with larger ports?
you could do a little "port" work to make the gasket flow ... thats the only gasket I could find that was close... to each his own.
gaskets
fel pro 1406
They might block some of the port but the best i've seen |
Ultra Seals, as for them blocking the port. Nothing a die grinder can't fix...;)
| All times are GMT -5. The time now is 05:46 AM. |
