Thinking about getting a Cam need some advice
Old Oct 1, 2003 | 09:07 PM
kyzer soze's Avatar
Finally getting my retro check from work sometime late next month. My budget is $2k estimate. Here's what i have now:
cai
catback
lt headers not installed yet
sfc's
sz 50 ep tires
Car is a m6 with 3.42 gears (i think)
going to install my headers, y-pipe and new shocks also which cost:
hooker y-pipe $169
header and y-pipe install $450
bilstein hd shocks $329 (4)
total $949 cost
That leaves me with $1051 left for mods
What kind of cam should i be looking at maybe a cc305? Is this enough money for a cam, all the parts i need and a tuning from pcmforless? My car is my daily driver so i would like it to be very streetable. How much power gain do people get with a cam? . Am i going in the right direction with getting a cam? I was thinking about just doing all my suspension work first. I don't have a problem with traction now. Im clueless when it comes to cam and heads and what i need. Im using the search function now. I feel pretty stupid not knowing anything about this stuff but please reply back i need all the help i can get.
thanks
Old Oct 1, 2003 | 09:20 PM
S.J.S.'s Avatar
streetable huh....thought about the Hot Cam? comes with the whole kit for like 490. here....
http://www.fbodyeurope.org/gallery/7_flpidle.MPG
Old Oct 1, 2003 | 10:26 PM
LimitedEd1LE's Avatar
If you are looking for a good streetable cam on a budget, then I would go with the Hotcam. The kit is very affordable(around $500) It's a great kit to wake up your Z on the street. After you get that cam I would get pcmforless.com to give you a good tune, because he has a great tune for the Hotcam. Consider that, or if you want a little bigger go with the Comp Cam 224/230 kit from www.cmotorsports.com You get a little better springs and RR. The kit should only cost about $625.
Old Oct 1, 2003 | 10:34 PM
chasmanz28's Avatar
hey is the cc305 and that cc224/230 the same cam?
Old Oct 1, 2003 | 10:38 PM
94formulabz's Avatar
no, the cc305 is 220/230 (from memory), the 224/230 is an XE lobe series grind
-brent
No it is not the same as the cc305. THe 224/230 is I believe the cc503 cam. But they are definitly not the same cam at all.
Old Oct 1, 2003 | 10:47 PM
chasmanz28's Avatar
so out of those 2 cams the 224/230 would give you more HP?
Old Oct 1, 2003 | 10:52 PM
kyzer soze's Avatar
thanks for the replies. What kind of power can i get out of the hotcam? Are their people out their running say 11's with it? I plan on doing work to the heads later on. Hmmm is their a bigger difference in power with the 224/230? thanks
Old Oct 1, 2003 | 10:58 PM
If you are planning on doind some head work later on then I would definitly get the 224/230 from cmotorsports. I have heard many people say that they regretted getting the Hotcam because it was not enough cam for them. I have heard of one guy running 12.2 with the Hot cam, but thats a good driver and some big tires too.
My buddy has the Hotcam in his 94 A4 and I can beat him pretty good. It's not a bad cam, but it's not too big.
Old Oct 1, 2003 | 11:01 PM
chasmanz28's Avatar
yeah i went to comp cams site, and they dont break it down to well, would a cc306 be close to what a 224/230 is?
Old Oct 1, 2003 | 11:07 PM
No the cc306 is a pretty big nasty cam for the LT1. It is the 230/244 cam. I wouldn't get the cc306 unless you have some head work done.
Old Oct 1, 2003 | 11:13 PM
chasmanz28's Avatar
limiteded1le, is there a chart you have that can break it down for me, like the cc306 being 230/244, i would like to have the comparsion chart to look at for myself
Old Oct 1, 2003 | 11:22 PM
Hmm, i dunno, i'd probalby skip them both and go with the cc502
[/B]
Here is a comparison. You have to go down to page 198. Whoops, i see you've already been there. I don't know what you mean they don't break it down that well???
Camshaft part no->
07 means lt1/lt4->
306/502 ect is what we use for lingo->
8 - I'm not sure?
The durations and lifts are right aside of the part numbers.
Oh yeah, also note the recommended applications they list on the left hand side
Old Oct 1, 2003 | 11:35 PM
kyzer soze's Avatar
Is the comp cam 224/230 and the xe 224/230 cam in your sig the same thing? How much horsepower "estimate" would you think i would get going with the 224/230 cam and tuning from pcmforless?
thanks
Old Oct 1, 2003 | 11:37 PM
InjectedSS's Avatar
The only advice you need is to call SETH at COMBINATION MOTORSPORTS
