CamaroZ28.Com Message Board
-   -   Is there a way to check timing? (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/there-way-check-timing-455445/)
Rage Jun 11, 2006 11:47 PM
Heres the deal. I put an LT1 in my car (87 IROC) and I cant get the thing to run right. It ran fine before being pulled from it's donor, and while I hade it out, I replaced the OPTI and plugs wires, water pump, the usual stuff. But it seems now that my timing is way off. The car cranks starts and runs like crap for a few seconds, and then sputters to it's death. I have checked the firing order at least 5 times, it's all correct. I have checked my wiring and it appears to be right. I have tried to find any possible grounds that may not be grounded but I think I have them all(how many are there btw). I'm very desperate for answers, I miss my car alot! Please help in anyway you can. Thank you.
WeirdRich Jun 11, 2006 11:54 PM
Re: Is there a way to check timing?
if its an early style opti, its pretty easy to put on wrong and not really know it. If its a later style, its a lot harder. but eather way, thats probably your problem. I installed an opti wrong once a while back and it had the exact same symptoms.
Rage Jun 13, 2006 11:03 PM
How is it installed right then? What did you do wrong when you put it in? It's a 94 btw.
shoebox Jun 13, 2006 11:31 PM
Originally Posted by Rage
How is it installed right then? ...
Install like this.
Rage Jun 14, 2006 10:57 AM
Yeah, that's what I thought. All of them are keyed and would be close to impossible to install it wrong.
Injuneer Jun 14, 2006 12:05 PM
That's what everyone thinks...... WRONG. It is very easy to assemble both style Opti's incorrectly. I'd say it happens in at least 10% of the installs.
DrewHMS97SS Jun 14, 2006 01:28 PM
its 95-97 that have the dowel pin from the cam into the opti ya?
OBE1 95Z28 Jun 14, 2006 02:48 PM
Have you verified other contributors like fuel pressure, hot spark, fouled plugs, etc?
Rage Jun 14, 2006 04:35 PM
Indeed. I check fuel pressure, it is a constant 40 psi, the plugs are new. I am getting spart to all of my plugs, it just seems as if the timing is off.
blkchevyz Jun 14, 2006 04:58 PM
what year motor is it? did you use the factory wiring harness?
Rage Jun 14, 2006 05:01 PM
It's out of a 94 Z28, and yes I used the factory 94 harness. I bought the Opti Unit from O'rielly's and I bought the MSD cap and rotor.
blkchevyz Jun 14, 2006 05:02 PM
you are using a mass air flow sensor correct?
what did you hook the computer power wire to? make sure its getting power all the time when the ignition is on.
Rage Jun 14, 2006 05:05 PM
There are two power wires going to the ECM and both are hot in start and run. Yeah, I also purchased a new MAF from O'rielly's. Everything is hooke up right as far as I know, but if you guys have any suggestions, Im open to them all.
WeirdRich Jun 15, 2006 02:43 AM
check the opti again, what do you have to lose? its easier than you would think to screw it up.
grandnational007 Jun 15, 2006 02:47 AM
CHECK YOUR COMPUTER!
you may need to reflash it, I had this same problem about a year ago...
the computer had kicked the bucket on mine
car would start, run for a few seconds, then sputter out and die
possibly shorted it out during engine swap
