is there a replacement for the optispark?
Old Jan 28, 2005 | 02:30 AM
nin97's Avatar
Question is there a replacement for the optispark?
i dont mind it...but i was wondering if there's anything out there that replaces the optispark for the LT1s?
Old Jan 28, 2005 | 02:40 AM
jonota's Avatar
Re: is there a replacement for the optispark?
There are several aftermarket choices, most of which INCORPORATE the optispark, and several very high dollar aftermarket ignition systems that actually do completely replace it. I have my eye on the Delteq system, which removes the main body of the optispark (rotor portion) and uses 4 cadillac ignition coils mounted to your driver's side valve cover and a computer module. It is effectively a distributor less system, but it still uses the original optical sensor. This is NOT what usually fails. Let me know if you'd like more info
Jonota
Old Jan 28, 2005 | 02:42 AM
97WS6SCharged's Avatar
Technically the cap and rotor remain in place, they just cease to function.
Old Jan 28, 2005 | 02:45 AM
BlackLT1_TX's Avatar
Well, thats a open ended question
People have been known to drill out a hole in the back of the LT1 intake manifold and use very slim distributors. This requires alot of work and is not nessacary in 99% of cases.
Alot more people (including myself) are ditching the "Spark" part of the "Opti-Spark". With a Opti-less system from Delteq you still use the opti for cam timing, but you have individual coils controled by a ICM that is fed from a Opti-Box that takes its signal from the PCM.
It is not truely "opti-less", but has been known to make the opti alot less prone to fail, and opti's that have failed in some cases dont even have to be replaced if you use a Delteq setup.
Visit there site at www.delteq.com
Old Jan 28, 2005 | 04:01 AM
n2oblkz
Guest
Posts: n/a
There are a few options, one of which is the Delteq, which is one of the best.
The others are:
http://www.dynotech-eng.com/dynaspark.htm
and the LTCC ignition system.
Old Jan 28, 2005 | 04:31 AM
Yep, the LTCC works really well. It's a bit more work to install than a Delteq system though.
Dark Zeiro
Mar 11, 2015 07:15 AM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
brentbrowning01
Dec 3, 2014 10:36 PM
ScottZ
Mar 3, 2004 01:34 PM
