Testing Injectors at home?
Is there a way to test / clean injectors at home? I bought some used 30lb SVO's on ebay and would just like to make sure they are clean. They apparently only have 2000 miles on them. Any ideas???
Re: Testing Injectors at home?
The only good way I can clean them at home is to hook up a can of injector cleaner to the fuel rail and let the engine run off the injector cleaner until it stops. Does a great job. But you want them checked and cleaned BEFORE you install them and that would have to be done by a shop with with an utrasonic cleaner and a flow tester.
I can't think of a way to clean them, but you could test them by disconnecting an injector from your car while it's running and one at a time test the injectors you bought.
