tell me if this sounds like the opti
If Im cruising at 55 in drive and I dip into the throttle a little bit I can get it to backfire. If Im cruising at 70 in over drive and dip in to it just right it feels like it has a dead spot where it will stumble real bad then go. If Im crusing at low speed and just bearly have my foot on the gas it feels like it misses. Also if I floor it from a dead stop it takes off perfect but when it gets into the upper rpm it feels like it is losing power. I am running stock plugs and opti and have 82,000 on the odometer.
Re: tell me if this sounds like the opti
I mean they have never been changed. The coil is newer it is the msd coil I have to run that because I need two ports one to plug the digital 6 ignition into. I wanted to put off the nightmare of changing plugs until I got headers, but I might as well do it now.
Dylan Latshaw
Mar 21, 2015 09:48 AM
