CamaroZ28.Com Message Board
-   -   TB problems help (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/tb-problems-help-303503/)
Dexter Sep 23, 2004 04:50 AM
TB problems help
Ok me and my bud put on a new throttle body to on my 1993 formula today and everything was fine until I give it gas and the it sticks open a little till you pop the hood and push the return back.Any suggestion guys Im killing my brakes at the red lights. :confused:
Fuels94TA Sep 23, 2004 08:46 AM
Re: TB problems help
just double check the linkage to see if anything is blocking it from movement. Also spary carb cleaner on the return spring.
