Tb Gaskets
Old Jan 21, 2004 | 02:25 PM
MRCAIN's Avatar
Tb Gaskets
Has anybody ever had a idle problem due to a bad gasket on the throtle body cover, the plastic one on top. I was going to make a new one, removed the old one and replaced the rubber gasket with the orig, is this a prob or can I get a new one and if so a part number. My car is running rough like a vac leak, but can't find.
95 z28 lt1
Old Jan 21, 2004 | 02:26 PM
speed_demon24's Avatar
The dealer didn't sell the gasket seperate, so I just bought a tb plate from thunder racing that came with the screws and gasket.
Old Jan 21, 2004 | 02:30 PM
Here is the GM gasket.
Old Jan 21, 2004 | 02:38 PM
MRCAIN's Avatar
but will this cause a rough idle like in my case?
Old Jan 21, 2004 | 02:44 PM
A leak at that gasket is not a vacuum leak in the strict sense, but could slightly upset air/fuel calculations. Really nothing that the pcm could not compensate for. If you need a gasket, then you definitely should replace it, but I would not expect it to solve too many problems. I would get the gasket swapped out and then see what happens.
Old Jan 21, 2004 | 04:09 PM
MRCAIN's Avatar
thanks for the input, I plan on getting a new gasket today, do you have any suggestions, I just got the car back together, and found this prob. fixed my piston, rings ect, now, i need some advise on this new prob any would be appriciated.
Old Jan 21, 2004 | 04:44 PM
fozziez28's Avatar
i have a rough idle with a surge, but mine is plug wire arcing, which im gonna fix this weekend. -Michael
Old Jan 22, 2004 | 10:33 AM
MRCAIN's Avatar
SURGE? what is this condition, I'm experiencing some "surging"
i guess, I'm not sold on the idea of a vac leak, however, my wires may be at fault as well, considering I just got the moter together. is there a way to tell? and where are the wires most likley to be arcing at with the stock manifold
Old Jan 23, 2004 | 12:51 AM
fozziez28's Avatar
I dont think you can see the plugs from above to determine if its arcing. I have headers and its clear as day to see it. I can see blue spark coming on the plug wire boot. I'm gonna replace them this weekend, hopefully. It sound like my problem, my car shakes at stoplights, and rpms jump slightly. As the problem progressed i gained a backfire under acceleration too. If these are your symptoms then i would check out the wires, for sure. -Michael
magman
Apr 15, 2016 03:08 AM
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
WobblySausage
Oct 7, 2015 02:44 PM
pepon214tx
Sep 20, 2015 04:48 PM
