TB bypass
Where did you guys find the tube to connect the coolant lines together. Already been to Lowe's, Home Depot, Advance and O'Reily and had no luck.
I guess I will try a brake shop in the morning unless someone can advice me otherwise. TIA |
no parts needed by way of this method courtesy of Shoebox
http://csce.uark.edu/~jgbertr/rb/tb_bypass.jpg jason |
Yeah, just connect the right hand side line directly to the left hand side opening. Throw away the left hand side line.
I guess is works the same on a 93??
no that method wont work on your car or mine in that sense. only 95+
you will need a connector. |
3/8" brass hose barb for connection on 93-4 only.. 95 up need nothing..
:cool: |
Thanks for the help. I'll hit a few more places in the morning.
I used two air-line repar fittings for air tools (1 female/1 male) to do my 93.
Dan |
I got my 3/8" barbed connector at Home Depot
Got mine for ACE hardware.
Thanks again guys.
| All times are GMT -5. The time now is 06:22 AM. |
