TB bolts
I bought a use 58mm bbk TB a while back it did not come with the bbk allen bolts. I ended up using 3 stockers and then i took the 4th bottom passengerside ground off all the edges the sloted it and used a screw driver to screw it in. Does anyone know where to pick up the bolts that are made for the bbk so i can ditch my getho bolt mod.
Re: TB bolts
The bolts are M8 bolts I think, rather than the 5/16 they look like. You need a long allen bolt for that measure the length of the thing and maybe we can find you something.
Bret |
