Tapping a fuel rail
Anyone tapped a fuel rail & welded an AN fitting on it for nitrous use. Schrader valve has a FP gauge on it. Thanks.
Gary |
I had a hole drilled, and a 1/8" NPT female bung welded in for a fuel pressure sensor:
AutoMeter Fuel Pressure Sensor on Passenger Side Rail There are also -6AN fittings welded into the back of each rail for fuel supply, and a -6AN fitting welded to the front crossover pipe for return. |
