T/A headlights, drivers side makes noise for about 5 seconds after it goes back down
Mine did the same thing awhile back. I got these and haven't had a problem since:
http://www.bfranker.badz28.com/headlightfix/index.htm
Or you could take the gearpod apart and turn it around so it using the other half of the gears.
Tails
Tails
The gear in the headlight motor is stripped. buy a metal gear for it
If you don't want to pay for that right now, you can always turn the gear around. You see, when you turn your lights on, you only use 1/2 of the gear. Then when you put them back down, it uses that same1/2 of the gear in the opposite direction. The other side of that gear is never used in the life of that motor...unless, you turn it around so it can use the unstripped side of the gear. This will last another few years, but eventually it will strip it out. GM put cheap plastic gears in there...who knows why.
squarehead
Nov 21, 2014 08:02 PM
Jul 4, 2005 05:00 PM
Patrick Davies
Aug 8, 2002 08:30 AM
