Swaybar
Old Oct 5, 2004 | 05:34 PM
dabez1's Avatar
Swaybar
What are the benifits of having a front sway bar and the benifits of not having one?
Old Oct 5, 2004 | 05:57 PM
Fuels94TA's Avatar
Re: Swaybar
The benifits are when you do a hard corner turns the front tire will be planted on the ground with min. body roll. Also if you removing it can can help your 60ft times at the track.
Old Oct 5, 2004 | 07:13 PM
funina91ss's Avatar
Re: Swaybar
I trashed mine and I am happy with it. But it is not a corner carver by anymeans.
I would suggest you pull off your endlinks and zip tie your sway bar so it won't flop around just to see how you like it. I wanted max straight line traction so I took mine off.
Old Oct 5, 2004 | 09:29 PM
stereomandan's Avatar
Re: Swaybar
Well, it's a trade off. A very stiff front sway bar, like I have (Suspension Technique's 35mm solid bar), will make a HUGE, HUGE improvement in handling. It can also hurt your launch because it doesn't allow the front end to come up as easily and transfer the weight to the rear. I love the trade off though.
The stiffer sway bar reduces body roll, and it also helps with camber control.
Dan
Old Oct 5, 2004 | 11:39 PM
Bud M's Avatar
Re: Swaybar
I would never consider running without a front swaybar on the street. The few pounds you save would not be worth the increase in body roll. My 32 mm front swaybar is one of my favorite mods.
football4life
Oct 4, 2015 07:48 AM
realistyc
Jul 28, 2015 07:32 PM
Jul 2, 2015 11:39 AM
bitchinangel01
Jun 11, 2015 10:15 AM
Dr.Mudge
Oct 23, 2002 12:53 AM
