Swapping '95 LT1 into a '94 Z28
What do I need to know as far as diffences between the '94 and '95 LT1? I know I'm dealing with a vented optispark now. The connector looks the same but only deeper, so it looks like I'll need a different optispark harness. What other subtle nuances do I need to be aware of to make this swap successful?
TIA Steve |
Re: Swapping '95 LT1 into a '94 Z28
The vented opti will need a fresh air feed from the intake ducting (anywhere between the MAF and the TB) and a vacuum source off the intake manifold.
if you are using the 94 engine harness, all you will need is the vented opti wiring harness ( https://www.casperselectronics.com/M...Category_Code= ) , and the vented opti vac harness
Perfect!
Thanks guys! |
