Suggest a ramp.........
'95 Z28......anyone have a ramp suggestion? Will the nose/dam clear the Rino 12,000? Not looking to spend much on these, just looking for something secure and enough room for an oil change. thanks!
Re: Suggest a ramp.........
I got the rhino 12,000 low profile for my 02 vett and the only thing that gets caught up is the plastic shield sometimes when driving off the ramps. these cars suck when it comes to this and i have just started jacking my camaro and vett by the front and then lower it on the ramps to prevent hitting the plastic shield. that shield on the 95 will rip the hell outta the bumper and damage it when backing off the rhino ramps. i know it sounds dumb but considering jacking the car up and then dropping it on the ramps.
I've got the Rhino low profile ramps. Use them with my Formula. No problem with the air dam or anything else hanging on them. If a car is lowered, I can see there could be a problem.
I've got a set of UR2000 style ramp extensions for my existing ramps. They work well for me. Only thing is that I have to brace the ramps with some 2x4's to keep them from sliding across the concrete floor as I drive up on them.
https://www.google.com/search?q=ur20...w=1280&bih=632 |
I have Rhino Ramps and have had zero issues with stock height 96 Z 28.
I guess they do sometimes slide a little..... |
Mine work fine on my slightly lowered Z.
