Stupid Question
Old Feb 28, 2003 | 03:56 PM
Thor39's Avatar
Stupid Question
Are the 1993 trans am and camaro engine bays the same set up with wires and the places things are put?
The reason for asking is i bought a parts manual kinda like ALL DATA but just for 93-00 trans am will it match my car when i start putting the engine back in?
Thanks for the help
Old Feb 28, 2003 | 04:19 PM
Gripenfelter's Avatar
all 93s were the same with all other 93s but different than other years wiring routes.
Old Feb 28, 2003 | 04:44 PM
Mizz96Z28's Avatar
How can they include 98-00 with the 93-97? Wouldn't they have different setups because of the different engines? Just a thought
Old Feb 28, 2003 | 04:46 PM
Jcb890's Avatar
i would imagine that all 93s would be very close and that the 93-97 would be quite similar. however, 98 was the 1st year of the LS1 and i would imagine since it is a different engine, things would be quite different under there...i may be wrong tho.
Old Feb 28, 2003 | 10:10 PM
Thor39's Avatar
You are able to select diffrent years and it shows diffrent diagrams for each car it show every thing from stero wireing to how the raditor hoses hook back up to to putting a block back together
Old Mar 1, 2003 | 12:02 AM
1993 has differences to 1994-1995 (which are much the same). 1996-1997 are much the same to each other, but not to earlier years, mostly in regard to diagnostics being changed from OBD-I to OBD-II in 1996.
If you have all the separate diagrams available, just use the one for your year.
Magenta_Hearts
Mar 5, 2015 07:01 AM
cmdeshon
Dec 27, 2014 10:06 AM
brentbrowning01
Dec 16, 2014 06:35 AM
ChrisFrez
Dec 15, 2014 03:09 PM
Brent94Z
Mar 21, 2002 04:44 PM
