Stupid Question #3: Reinstalling the Opti
Old Mar 16, 2003 | 08:09 AM
NONO5.0's Avatar
We're about ready to re-install the opti and have the timing marks lined up and everything in order. On the back of the opti, there is a 1 and a 6 posted on it. The clover looking piece I noticed has one particular notch (like a keyhole) However, the way it would mount on the cam, the keyhole would be set with the 6 on the opti. Is this correct? If not, how do I need to install the opti to make sure I get everything right?
Thanks for any help!
God I'll be glad when I finish this swap!
Old Mar 16, 2003 | 08:36 AM
joeSS97's Avatar
Do a search for street illusions opti install guide.
Old Mar 16, 2003 | 10:22 AM
vodoo-chile's Avatar
Here is the link for the above mentioned install guide:http://www.streetillusionsracing.com...ll/Cam/cam.htm
The clover notch goes over the cam dowel and is the only way to install the Opti. Good luck,
Kyle
Old Mar 16, 2003 | 11:10 AM
Mikey97Z's Avatar
Yup. When the timing marks are lined up on the sprockets the engine is at #6 firing position. Both dots pointing up at 12:00 would be #1 firing position.
Old Mar 16, 2003 | 04:08 PM
It does not matter where the dowel is, as long as you put the special slot over it. It will be in perfect time. The 1 and 6 are only there for reference.
Sergio
Jan 27, 2016 04:27 PM
grgguy
17
Feb 23, 2015 07:57 PM
cmdeshon
Dec 27, 2014 10:06 AM
ChrisFrez
Dec 15, 2014 03:09 PM
Injuneer
Dec 15, 2014 09:36 AM
