stud and rockers
Old Apr 13, 2006 | 08:23 PM
Zeueses 97 RamAir's Avatar
stud and rockers
Rockers are pro comp shaft mounted 1.52 sef allighning today i crank the car up i hear the slapping sound stud snapped. I pull the cover off and the polylock with half the stud coms off what could have caused this.. I have 2 sets of heads trying to take off the stud how do you get those things off
Old Apr 14, 2006 | 12:32 AM
Re: stud and rockers
well everything is back on hopefully things should go well
Old Apr 14, 2006 | 01:52 AM
Since the steel rockers polylocks are to tall im using the aluminumr rocker polylocks in there place they should be fine right...because they are shorter...
Old Apr 16, 2006 | 11:20 PM
ttt
Old Apr 17, 2006 | 12:15 AM
HardcoreRM125's Avatar
Is it possible that you had the pre-load cranked down way to tight and it somehow put all the extra stress on the stud and broke it? I would think this would collapse a lifter first but if your running a solid roller or something ? Who knows ?
Also, it SHOULDNT hurt it running aluminum poly locks ... I would check with someone who has more experiences building engiens first though ...
Old Apr 17, 2006 | 12:35 AM
Yea I have lt1 97 thats what I thought also I put a new stud fro the other lt1 heads i have and barely tightened the polylock and tightened the hex screw. Lucky I cranked the car up and heard it knocking a little then it changed exhaust tone and started to slap louder pulled the cover pulled the stud out and replaced it... lucky
13qtr
Oct 28, 2016 08:11 PM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
mmf_1013
Sep 12, 2015 08:56 PM
Daluchman1974
Sep 11, 2015 06:12 AM
