CamaroZ28.Com Message Board
-   -   stud girdle (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/stud-girdle-622710/)
davisck2 Jul 23, 2008 10:57 PM
stud girdle
can any one tell me if any one makes a stud girdle set up for a 96 lt1?
cnorton Jul 24, 2008 07:57 AM
I used a Comp Cams small block girdle for two years on my race motor. I had no problems with the girdle itself other than the fact that it didn't stabilize the valve train adequately at 8200 RPM. Frequent valve adjustments were necessary until I switched everything to a T&D shaft rocker system.
Ken95Z28 Jul 24, 2008 10:47 PM
The biggest issue would be to find one that does not interfere with the center bolt valve covers. Next would be to find a set of valve covers that would not hit the stud girdles. Moroso makes one that will do that or you can modify a set.
I bought a summit sbc girdle and did this.
http://www.teamandersonracing.com/Pi...StudGirdle.jpg
new2chevy Jul 16, 2015 11:22 PM
Re: stud girdle
So the Summit stud girdle lined up properly with the studs on the factory GM heads?
Hopefully my tall valve covers would clear this girdle.
bw_hunter Jul 17, 2015 05:32 AM
Re: stud girdle
The rocker stud locations are the same on all small block Chev's since, at least, 1986. The only problem I had was interference with the center bolt valve cover bolts. I just notched them out and all was good.
If you install the tall rocker nuts on the rocker studs and don't have interference problems you're pretty good to go once you install the girdle.
Good luck!
new2chevy Jul 17, 2015 12:07 PM
Re: stud girdle
Thank you for your reply.
Much appreciated!
