Strange Electrical Problem...please help!!
I have a really bizarre electrical problem. My signal don't want to work at all!! Here's what happens...My fourways work fine! When I signal left nothing happens, not even the green interior arrows light up. When I signal right the interior green arrows both light up but I still have no outside signals. When I hit the brakes, the interior arrows light up. I have no idea where to look. I assume my bulbs are fine because my fourways work fine! Any ideas???
You need a new flasher.....it is located under the steering wheel, you will need to remove the cover. There anywhere between 3-5 dollars at your local auto parts. Ask for them, and you will know what you will be looking for under the cover. It is a simple plug in and out.
Nayr
Mar 3, 2023 08:34 PM
tdigger9899
Sep 7, 2015 10:56 AM
