Stock plug gap size?
Old Mar 15, 2003 | 04:14 PM
LT1Thunder's Avatar
Question Stock plug gap size?
I was wondering two things actually. As far as autolites go, what is the stock plug number and also what is the gapping of it. The reason that I ask is because after pulling out a plug just now, I found that there are 104's in there gapped at .040! This leads me to think that at some point my car had nitrous on it. So if anyone could help I would be grateful. Thanks
-Rick
Old Mar 15, 2003 | 04:27 PM
RamAir95TA's Avatar
.050" is correct.
Old Mar 15, 2003 | 04:36 PM
LT1Thunder's Avatar
Thanks I didn't even think to look there! I wonder why these plugs were put in instead of the stock ones. The only thing I could think of is that it did have nitrous at one point. Also it's a little dark and smells like gas, what does that mean....running too rich or something?
Old Mar 15, 2003 | 08:02 PM
grygst76's Avatar
Because the plugs were gapped small and the heat range was more then likely off you were not burning all the gas in the cylinders, it needs a bigger gap to allow proper combustion. the bigger and hotter the spark, the better fuel burn. I always suggest .48 for a gap just in case you decide to go with nos in the future
Old Mar 15, 2003 | 08:05 PM
smokindastangs's Avatar
why didn't you just call autozone or something?
Old Mar 15, 2003 | 10:11 PM
Don 97 SS's Avatar
While .050" is the correct answer, I am surprised that the gap is that large. I've never owned a car with that much gap in the plugs. I would think .040" would be better for me especially since I have an MSD Ditgial 6+.
Is any body running a tighter gap?
Old Mar 15, 2003 | 10:43 PM
JSK333's Avatar
.050" is the standard gap. I don't think it's abnormally large. The stock gap on my '90 Caddy is .060".
It does sound like someone had (or was planning) nitrous on your car from the plugs/gap in there, though!
HectorM52
Jul 30, 2017 11:46 AM
jayblev95
East South Central
Feb 15, 2015 02:26 PM
jayblev95
Jan 6, 2015 11:52 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
