Stock 6speed Owners & 1/4 Times
What did you guys run when you were totally stock?
Do a search there are plenty of posts on this subject.
I had rims on the car at the time that actually slowed me down, I ran a 14.03 at 100.02mph. *I sucked outta the hole and spun a bit too much on the 1-2 shift* I think 13's were definately in the car and if I had the factory rims on it which would be much lighter then my chrome wheels from what I've read I would have probably been in the 13.80s at 101 to 102.
well, i had a replacement muffler (flowmaster) but not cat back and i had an air foil in and i ran a 14.2. i am not a pro at driving the stick and a lot has to do with what the temp is or what altitude your at. track prep and driving skills are also important. i am going down to run again but now its a little warmer but i installed a cai so we will see what happens.
I got a 14.02@99.77 on a 2.06, 60'. I slipped the clutch a little, at pull out, my launch RPM was around 2500. I did that right afterbuying it. I was having launching issues, so I dropped tire press. to about 22 psi. and that is the result. Try a search on this I have seen this thread before. So Espo, what did you run?? Or haven't you got the chance to run?
Few weeks ago, I took my Z out and got a 14.2 @ 98mph. I had lots of runs at 99mph one was as high as 99.8, so I don't know what was up with my mph on my 14.2 pass, but oh well. It was a very hot night and i was having bad wheel hop too. I could only get a 2.3 60'. So 13s were definately in her. Only mod I had was a SLP cold air kit and 17" wheels, so they probably canceled each other out. :)
Oh yeah, bout the wheel hop, turned out one of my LCAs was loose and was causing it really bad. I've already replaced the stock ones now though, so should see 13s easy this fall. |
As close to stock as I had it, I went 13.63@102.32 with a 2.14 short time.
That was with WS6 rims and SZ50's, K&N CAI, Hypertech powercoil, B&M Ripper, and a flowmaster muffler with a gutted cat. |
i was able to get 13.9-14.1 with mine bone stock and it was always right around 100-101
13.95. Sorry, don't remember the MPH. 1996 z28 6 speed. Totally stock.
I ran 13.88 on nittos with a k&n filter(stock air box and all the ducting,coolant though the throttle bodyETC) , and some good gas, stock everything with 80,000 and change on the clock. Track altitude of 900 ft.
13.79 dont remember the mph. but i also ran a 13.82 the next 2 times down the track.
14.1's at 98-99 mph.
Headers, cold air, and drag radials got it mid 13's at 101. |
I must have 100 timeslips that say 14.0@98. Then I put a CAI on the car and took the spare out and went 13.8@101
