CamaroZ28.Com Message Board
-   -   starting problems (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/starting-problems-93772/)
5thCamaro Mar 14, 2003 09:05 PM
starting problems
I have been trying to figure out a starting problem that is a pain. The engine will not want to start the first try acting like it is out of fuel. So I turned the key (not to start) to on heard the fuel pump kick on and shut the key off. I will repeat the two or three times until I hear the pump bog down. The it will start as soon as I turn the key past the on position. Why am I loosing the fuel prime?
NeoSNK Mar 14, 2003 09:41 PM
The pump is probly going bad.
Donny O Mar 14, 2003 11:28 PM
I second that...mine did the same exact thing. I finaly got tired of having to prime it 2-3 times so replaced with a walboro 255.....all fixed and happy now!!
5thCamaro Mar 15, 2003 07:48 AM
where is the pump, I hear it in the back so does that mean it is in the tank?
doodad Mar 15, 2003 08:16 AM
It's in the tank alright. Another symptom is if it starts better with a full tank. You are gonna love how the GM "engineers" designed the method for changing the dang thing. Hint: Your exhaust and axle are in the way.
