SS Motor
What is the difference in the 97 SS motor versus Z28
I know the cam and tune, anything else? |
Originally Posted by 7designs
(Post 6148593)
Originally Posted by RamAir95TA
(Post 6148608)
There is no difference in the engines themselves. Cam and tune are the same.
(Post 6148613)
There has to be a difference, the SS is rated at higher horse power.
(Post 6148617)
The difference is in the SS-style airbox and the freer flowing exhaust, but the motors are identical. Keep in mind that the rating is just that - a rating - and doesn't prove a thing. Most Z28s and SSs will dyno (under identical conditions) about the same.
thats right there is no diffrence, the engine is basically the same except for few engine exterior components like the air intake box and the exhaust muffler as RamAir95TA said
I thought the SS had 4 bolt mains?
Originally Posted by Wooshie
(Post 6149237)
(Post 6148613)
(Post 6149318)
Only cars that got the 4-bolt mains were Corvettes, replacement LT1 short blocks/crate motors, and (debatably) some of the anniversary LT4 SSs/Firehawks. All SSs, Z28s, Formulas, T/As, WS6s, and Hawks got 2-bolt mains.
(Post 6149901)
Replacement GM short blocks or having them converted by a reputable machine shop?
I can show you a 30th Anniv. SS with a 1,350HP engine, running low 8's....but that isn't relevant to the question, either. |
Originally Posted by Prorac1
(Post 6149728)
That has to be my favorite quote of the week, lol. Eric L
But mine came with SS floormats so its faster.
Ram-Air Intake SLP Stainless Exhaust with quad tips and a 3 inch cat back pipe Eibach Suspension Oil Cooler 1LE Thicker Swaybars 1LE Control Arms 1LE Panhard Rod Torsen Differential and Aluminum Cover ZR1 Rims- 275/40/17 tires all around Hurst Short Throw Shifter Ram Air hood Revised Rear Wing SS Floormats SS Car Cover Am I missing anything? |
Originally Posted by Sick97SS
(Post 6151508)
ZR1 Rims- 27/40/17 tires all around
mine came with the SLP 2OTL
| All times are GMT -5. The time now is 08:47 AM. |
