Specs on Gm 846
Valve springs for gm846,comp503,305
Since I found out I can't run beehive spring with my sa roller rockers I am researching cams again I was going to go with the comp 466. Does anyone have the specs of the GM 846 cam. I like the specs of the Lingenfelter 74219 but they are a little on the high side. I changed the title cause I am back to deciding which cam to go with. I really like the lingenfelter 74219 but I am not going to pay that kind of money. What springs,retainers,locks should i go with on the above cams.
Re: Specs on Gm 846
Here's some information, and some:
cam I' E' Lift 1.5 Lift 1.6 LSA
stock 203 208 450 460 480 491 116
-845- 214 224 488 509 521 543 112
-846- 222 230 509 528 543 563 112
-847- 232 242 539 558 575 595 112
Dave.
Dave.
Re: Specs on Gm 846
If you run those sa rockers with a cam that big. I'd consider the arp pro series studs for 60 bux. Im debating using my sa rr's with the 503 cam. But i'll probably switch to nsa. Never liked the idea though of pushrods coming into contact with guide plates, and 100 dollar pr's.
cmsmith
Sep 14, 2015 09:09 PM
NewsBot
Sep 14, 2015 09:20 AM
