Specific Cam Question..
Old Sep 25, 2003 | 10:02 AM
rocmemphis's Avatar
Question Specific Cam Question..
I have a cam that I suspect to be a LT4 Hotcam. It is obviously a pre vented opti cam as it has a very short dowel pin (.300") and the hole in the center is too shallow to accept the vented opti.
My question is were there 2 different versions of the hotcam or did I get ripped?
thanks.
Old Sep 25, 2003 | 11:30 AM
Compstall's Avatar
Isn't there a part # stamped on the cam?
Old Sep 25, 2003 | 12:08 PM
rocmemphis's Avatar
There is not a part number anywhere on the cam. The only thing that is on the cam are I am assuming a build number and lot number. I printed out a GM cam spec sheet so maybe one of the numbers on the list will reference with the cam I have.
Old Sep 25, 2003 | 12:17 PM
zhevy-1's Avatar
The LT4 hotcam should work with any LT1 93-97. The only thing different, should be the dowel pin.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
jasonduaine
Apr 1, 2015 08:09 PM
grabbem88
Feb 22, 2015 11:16 AM
