CamaroZ28.Com Message Board
-   -   Spark Wire Routing? (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/spark-wire-routing-191147/)
NewbieWar Nov 9, 2003 04:49 PM
Spark Wire Routing?
well im under my car and im doin the wires now... i was just wondering about some of these things under here... ok first off the spark plug wire that goes to the spark closest to the drivers how does that wire get there?
it seems to be in a container or something...
do u think i should just abandon all those things wrapping all the wires together? and just let the wires hang?
im not sure how to take off the last wire, its like stapped to something and i cant really get it free... how will i take that off? and how will i replace it in the same fashion?
shoebox Nov 9, 2003 05:07 PM
If you don't follow the stock locations/looms (especially on the passenger side), your wires will end up shredded by the pulleys and burned by the exhaust manifolds. Do your best to see the retainers that are used and reuse them.
