CamaroZ28.Com Message Board
-   -   Spark Plugs (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/spark-plugs-506471/)
mannycamaro Mar 5, 2007 10:16 PM
Spark Plugs
Its hard change the spark plugs ?
How much time required ? Also I have hookers headers
LiENUS Mar 5, 2007 10:38 PM
Take off your alternator first thing, and then jack the car up. If you cant reach a plug from up top then go underneath. the one farthest to the front on the passenger side (under the alternator) is gotten from the top, with hooker headers im not sure which other ones need to be from the top or which on the bottom.
Jamon Mar 5, 2007 11:27 PM
Buy Advil :)
All it is REALLY is patience. It sometimes takes a bit long and tears up your hands, but just be careful and take your time. Try not to get frustrated, and it should take only about an hour or two.
danhr Mar 5, 2007 11:28 PM
beer.. lots of beer.... and a lot of spare time.... and a hot pocket
speed_demon24 Mar 6, 2007 01:19 AM
I have jethots but I think they are pretty close to hookers. I do 1-3 from the bottom, I take out the starter/dipstick and do 6-8 from the bottom, then 2-4 from the top, and 5-7 from the top. I can do it pretty quick now that I have practice, but if its your first time it will probably take a few hours. And if you don't have them I would get OVC wires.
2000GTP Mar 6, 2007 06:40 AM
Seeing that you have longtubes, that makes the job right there a heck of alot easier. Imagine doing that job on a stock manifolds car, it would be 10x harder. It can probably end up being a couple hour job.
mannycamaro Mar 6, 2007 12:37 PM
Thanks you, a lot my friends .....:)
94arcticwhiteM6 Mar 6, 2007 03:13 PM
really wasnt all that hard and i have stock manifolds. did all the ones on the driver's side froom underneath and the back 3 on the passenger side from underneath. the front one from up top.
snakeatinZ Mar 6, 2007 03:25 PM
:D LMAO!!!!!!! Its sooo true.
