sounds like loose or broken shocks when i hit bumps after replacing with slp takeoffs
it sounds like a chattering over every bump.i also installed eibach pro kit. any help?or experience with same problem?
Re: sounds like loose or broken shocks when i hit bumps after replacing with slp takeoffs
The rear shocks will bump if you don't get the top nuts tight enough.
That black shield is to keep dust out, I left mine off cause its not daily driven anymore.
It sounds like you need to tighten up the bolts on the rear shocks, mine came loose on the bottom bolts cause I did not tighten em up enough, check and see if yours are tight.
it sounds like all 4 and they were installed with a air ratchet so they are tight. what would the dust cover on the struts have to do with this? suspension has 100k ,anyone else have similar noise when hitting bumps?
F'n1996Z28SS
Aug 23, 2023 11:19 PM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
