smog/cc306
is it at all possible to pass the sniffer with a cc 306?
If it is, I would like to know as well.
I've heard of it done before but I highly doubt it would, even the XE236/242 would have a much better chance in passing since its got nice fast ramp up lobes which prevents loss of compression, the cc306 is a real soft ramp up cam which at low rpm's will pass all sorts of gas through the overlap & have lots of reversion.
i pass with mine everytime. All you need is a good tune and some alcohol. You will pass with flying colors.
Originally posted by BlkZ28M6 i pass with mine everytime. All you need is a good tune and some alcohol. You will pass with flying colors. My bone stock '95 barely passed on the rollers.... If your state does OBD2 plug-in testing (instead of a sniffer) and you have a 96-97, then you can probably get away with it with a good program that says everything is A-OK to the computer :) -Michael |
Ya, which state are you in?
Was it the roller test? I have onl heard of one guy passing the roller witht he 306 and he put on two factory cats. I barely passes in AZ on the roller test with my hot cam and that was using alcohol but a high flow cat |
I am hoping to pass AZ emissions with it next October. I know SnkSknr94 passed easy with the 305 after having it tuned for emissions.
Brandon |
i live in reno nv. have you guys ever heard of toluene, some guy told me if you put an quart of that in 5 gallons it will pass the sniffer every time. he also told me he used to make race gas with it 1 gallon to 4 gallons gas and a cap of tranny fluid
Originally posted by BlkZ28M6 i pass with mine everytime. All you need is a good tune and some alcohol. You will pass with flying colors. :D |
I passed with methenol on rollers in Illinois. Its OBD1 1995 I passed with a piece of junk high flow catco. I only had one cat. I barly passed but i did pass and that was all I cared about.
what are rollers? when i smoged my car they just stuck the sniffer in and hooked to a plucg wire
Originally posted by Brandon 95 Z28 I am hoping to pass AZ emissions with it next October. I know SnkSknr94 passed easy with the 305 after having it tuned for emissions. Brandon |
Yeah, Aaron did fail a few times, but those were on his performance tune, and trying that gaurenteed to pass crap. When he used the emissions tune it passed easily the first time. So I am hoping to get lucky and barely pass :D
Brandon |
Who's doing the emissions tune. I mean the one peopel will pass with ?
Brandon,
Which Cam are you wanting to use? |
