skip shift help!!!!!!
is there any way u can get the "skip ship" effect with out actually buying the skip shift part i seen some thing on a web site and it said u can disconect something from the computer and it is the same and buying the lil deal for 30 dollars if anyone knows please help me.....
Re: skip shift help!!!!!!
2.2K Ω 1/2 watt resistor you can get a pack of 5 at radio shack for like a 1$
http://www.installuniversity.com/ins...sity/index.htm go there and go under install documents on the left hand side, then scroll down and look under transmission "radio shack resistor" it shows you how to install it...its really easy and it works |
For the 94/95 OBD-I cars, all you need to do is unplug the harness connector from the skip-shift solenoid. It will set DTC 84 in the PCM, but it will not turn on the SES light. 96/97 OBD-II cars, you will get an SES light when you unplug the connector, so you need the 50-cent Radio Shack resistor. http://cjcfo.fbody.com/members/injun...E/T56Conns.jpg |
| All times are GMT -5. The time now is 08:19 AM. |
