Six Speed Conversion ?
I will be perfoming a six speed conversion on my 95 Z vert this
weekend. Have found a low mile 97 T-56 with all the parts for
the conversion. Here are the parts I am getting, and will these
parts cover everything I need?
---Tranny - fly wheeel,bell housing, pressure plate and clutch
---Crossover support, peddles, driveshaft,hydraulics, shifter with
boot, and 95 computer (programed for a t-56) and wiring harness.
Is the torque arm the same size for both auto's and t-56's?
I know many of you out there have perfomed this conversion,
can I get some input on any problems encountered and or
any guides or notes anyone has compiled.
Thanks in advance.
JMW
Thanks in advance.
JMW
You'll also need a new key cylinder for your steering wheel column, but I think you can get away with not having one. PM me and I can send you the conversion guide that he made... it's pretty good.
Im about to do this also in a month or two. Yes the torque arm is the same just a different bracket from the TA to the tranny should come in kit or wioth tranny. if you havent looked here already http://www.afrashteh.com/tranny_pics/T56.htm best writeup on the net.
Good Luck
Ps you dont need the M6 harness but if you already have it.... As for the cylinder key i dont think you need that either..Email Alex and find out.
Good Luck
carguyshu
Jan 22, 2017 11:19 AM
