single wire 02 sensor, '93 guys come on down
Old Jul 8, 2005 | 12:27 AM
JJJ93z's Avatar
Im looking for the o2 extensions b/c of my LT install, and all i seem to come across is the flat 4 wire and square connectors, i have no idea what to do with this, also the shop by me, ordered NGK o2s so i could see them and they have a 4 prong flat connector even though the computer said it was for a '93. not sure what to do , any suggestions would be appreciated.
Old Jul 8, 2005 | 02:02 AM
Bud M's Avatar
Re: single wire 02 sensor, '93 guys come on down
I spliced another piece of wire into the wire on the O2. Works fine.
Old Jul 8, 2005 | 06:19 AM
Kris93/95Z28's Avatar
That's what I did on my LT install too... Worked fine.
Old Jul 8, 2005 | 07:15 AM
Mr.Whitey's Avatar
I ordered my extensions through Casper Electronics. They will make anything you want, and the cost isn't bad at all.
http://www.casperselectronics.com/
Old Jul 8, 2005 | 09:56 AM
JJJ93z's Avatar
where did u attach it to? (im not quite sure what the diff is between the single wire and 4 wire ones) do u mean u just spliced on a 4 prong connector?
Old Jul 8, 2005 | 07:11 PM
Bud M's Avatar
I don't remember what the connector was like but it doesn't matter. Cut the wire coming off the sensor and splice in a long enough piece of wire to reach the bung. If you have more than 1 wire you have the wrong O2 sensor.
Old Jul 8, 2005 | 08:42 PM
93z383's Avatar
93 comes with a non heated sensor. It also is not a wide band sensor. The other wires you speak of are for later models with heated sensors etc. Ours are just run of the mill. If you do splice wires me sure you solder them. The sensors are used to transmit millivolts so a twist splice might skew the readings. On the other hand if you are thinking of getting an air/fuel ratio gauge you do not have to buy a seperate sensor for it to work, the gauge doesn't work with wide band sensors...
Old Jul 9, 2005 | 01:34 AM
JJJ93z's Avatar
so if i were to buy an a/f ratio gauge, all i would have to do is splice in another wire and run it to the gauge?
Old Jul 9, 2005 | 08:35 AM
InsuranceGuy's Avatar
Get AC/Delco O2's. Get extentions from Thunder Racing.
http://www.thunderracing.com/catalog...vid=4&pcid=156
Emil:93Z,383,Vortech,NOS
Old Jul 9, 2005 | 10:38 AM
whatsup's Avatar
Make sure to go check out the site for our 93's
http://www.speeddensity.org/
HectorM52
Jul 30, 2017 11:46 AM
cmdeshon
Jan 4, 2015 11:15 AM
Queens94z28
Dec 20, 2014 09:11 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
Red97LT1
Aug 7, 2002 05:45 PM
