CamaroZ28.Com Message Board
-   -   Shoebox, need help (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/shoebox-need-help-278643/)
SantaCruz163 Jul 4, 2004 01:07 PM
Shoebox, need help
Do you have the part number for the upper heater hose for a 95-97 F body? It's the hose coming off the top left of the water pump and has a bleeder screw on it.
shoebox Jul 4, 2004 01:32 PM
The hoses and coupler with the bleeder on it are available separately. See if this helps.
SantaCruz163 Jul 4, 2004 02:03 PM
Well I have a small hole between the water pump outlet and the bleeder section. What would you reccomend I do to fix it?
shoebox Jul 4, 2004 08:28 PM
Just get that hose and trim off the swaged collar that is on the bleeder pipe. Then, you can put the new hose on and secure it with a hose clamp.
SantaCruz163 Jul 5, 2004 09:52 AM
Thanks alot shoebox, you always have an answer:thumb:
