CamaroZ28.Com Message Board
-   -   Sfc (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/sfc-102954/)
PumpkinKingZ28 Apr 4, 2003 01:54 PM
Sfc
I need yalls opinion on where to get convertable sfc from. which brand is good and from what website. thanks in advance
LimitedEd1LE Apr 4, 2003 01:57 PM
I know the BMR SFC's are great. The BMR ones are very popular. I have the tubular ones and they rock. You can get them from www.ls1speed.com They normally have great prices. Check it out.
Thebeast431 Apr 4, 2003 02:05 PM
If I remember correctly the convertable come with built-in SFC's from the factory.
Dr.Mudge Apr 4, 2003 02:07 PM
I dont have a Vert, but I like the BMR subframes. Verts get some kind of bracing, that is why the aftermarket part is not the same as a T-top/hard top SFCs, dont expect factory stuff to be great all by its lonesome..
PumpkinKingZ28 Apr 4, 2003 02:07 PM
i heard about convert. having sfc from factory but if that is true, they are not that good:)
LimitedEd1LE Apr 4, 2003 02:12 PM
Even if the vert's came with some sort of SFC's from the factory they would probably be just some piece of stamped steal. I would not count on them being great, that's why I would recomend the BMR's. They will strengthen the chassis more than the stock pieces.
PumpkinKingZ28 Apr 4, 2003 02:19 PM
thanks guys
PumpkinKingZ28 Apr 4, 2003 02:24 PM
ok what is better weld on or bolt on sfc's?
TobyZ28 Apr 4, 2003 02:45 PM
Welded is always better ;)
