SES wire help plz
Took of AIR cant afford a tune now what wire can i cut to take out the ses light. Thanks in advance
Re: SES wire help plz
noone knows?
Disconnect the negative battery terminal and pull out the blue connector from the PCM.
Here are some instructions on how to do everything only you will be pulling out the wire #9 instead of 15. On 95s the wire is of brown color with a white stripe. It may be different on a 96, but the location is the same. Just make sure you find the numbers on the connector and take out #9. |
Thank you madwolf that did it.
| All times are GMT -5. The time now is 10:13 AM. |
