CamaroZ28.Com Message Board
-   -   SES Light WTF! (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/ses-light-wtf-338641/)
DataChild Feb 4, 2005 08:30 PM
SES Light WTF!
My SES light comes on at higher speeds (~60mph) .. and it stays on. I shut the car off, and it goes away. Then, when i get back up to 60, bam, on again. The car feels a little funny up there, too. I had it scanned, nothing showed up. Any opinions on whats wrong?
madwolf Feb 4, 2005 08:32 PM
Re: SES Light WTF!
What year is it?
78sixbanger Feb 4, 2005 08:48 PM
Re: SES Light WTF!
mine did the same thing, turned out to be an o2 sensor, even though it ad been replaced less then 3k miles earlier.
DataChild Feb 5, 2005 05:18 AM
Re: SES Light WTF!
its a 94, with LT headers, hotcam, gears, cai, etc..
ive also noticed it gets real shaky up near 80MPH.. vibrates my legs lol
this happen to u too, whoever had same prob and was o2 sensor?
30696bird Feb 5, 2005 05:23 AM
Re: SES Light WTF!
Do you still have the EGR system on the car? It seems like I read a post not long ago about a problem like this and that's what it was.
78sixbanger Feb 5, 2005 11:40 AM
Re: SES Light WTF!
Yep, car ran like crap at about 55+
Lt1t56 Feb 5, 2005 11:15 PM
Re: SES Light WTF!
My Z did the same thing except it did set a code, it was for EGR. To test the valve pull the vacuum line off the valve, take your fingers and push up on the diaphram then plug the vacuum port on the EGR valve, release fingers. If the diaphram falls down with vacuum port plugged it is defective.
Injuneer Feb 6, 2005 10:04 AM
Re: SES Light WTF!
Originally Posted by DataChild
.....I had it scanned, nothing showed up. Any opinions on whats wrong?
Are you sure it was scanned with the correct scan tool? If the light comes on, the code should be stored, as long as you had it scanned in a reasonable period of time.
DataChild Feb 6, 2005 01:20 PM
Re: SES Light WTF!
well, the light was on, he turned the motor off, then he did some things with the pins, resetting stuff or something... u know the paperclip thing? he did the same thing only with this 2$ tool.. then he scanned. now that i think about it, wouldnt that reset the code? ahh crap
Injuneer Feb 7, 2005 04:40 PM
Re: SES Light WTF!
No.... you can NOT scan a 94 by shorting the ALDL connector pins, and no, shorting them will NOT reset the codes. 1993 was the last year you could retrieve the codes by doing that. You need to use a "real" scan tool to pull the codes.
DataChild Feb 22, 2005 12:28 AM
Re: SES Light WTF!
Yea.. so heres an update... I was 100% sure it was EGR valve due to symptoms i read on other posts.........
then it dawned on me. I bought the car and it already had long tube headers, so the egr must be blocked off. sure enough, i check back there, and its definitly blocked off, however the EGR valve is still there. there is a little rubber nipple thing at the top. I duno if thats good or not...
So now im back at thinking this is o2 sensors. if anyone could re-read the problem i would love u forever! and ever...............
DataChild Feb 22, 2005 04:51 AM
Re: SES Light WTF!
nobody... i know im gona get it scanned tomorrow, just wanna see if anyone had any similar problems or an early diagnosis to ease my mind.
