secondary air injection
secondary air injection code, what is that exactly?
how do i fix it? |
thats your AIR
its an emmissions thing basically, its the 2 tubes going into the #1 and #2 primaries, which then go into the air pump on the drivers side head if i remember right there are more than one codes pertaining to it |
Need the exact code. There is a code for air flow failure to each bank of the exhaust (P0410) - could be failed check valves, pump not working; and another for electrical fault in the AIR pump circuit (P0412) - most likely a blown fuse.
its the P0410
Before Injuneer hurts his fingers from typing it again heres a link to a post with a more then detailed explanation of your problem
http://web.camaross.com/forums/showt...ighlight=P0410 |
| All times are GMT -5. The time now is 05:18 AM. |
