CamaroZ28.Com Message Board
-   -   scanmaster compatibility (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/scanmaster-compatibility-220398/)
30thannZ28 Feb 3, 2004 10:34 AM
I want to buy a scanmaster because I did most of the mods in my sig at the same time. I have a 97 Z, but it has a 95 Z ECU in it. Obviously, I still have the 97 size connector under the drivers side dash, so how would all this fair? I don't know much about the scanmaster, but I know I'll need it!
don't suppose anybody has a used one for sale.....
Brent94Z Feb 3, 2004 11:04 AM
Will work just fine and you'll even be able to read the trouble codes.
You'll be in the same situation as I was (originally OBDII but converted to OBDI) so this guide should give you what you need for the wiring...
http://www.bfranker.badz28.com/fbody/scanmaster.htm
Check this out too... great info here...
http://members.aol.com/InjuneerZZ/ScanMast.htm
OBE1 95Z28 Feb 3, 2004 11:50 AM
The Scanmaster doesn't plug into you ALDL port, it utilizes one of the lines. I just tapped into the line from behind the connector. Very useful tool to read PCM values real time.
