scaned car problem :(
first code was 82 shift solenoid a circuit, then it was 64 right o2 sensor too lean, then 97 4k pulses per mile fault (QDM)
i cleared the codes , ran test again n the code 82 came right back up i think the other 2 codes are when my car gets hot. cuz i ran it hard last night to get the check engine light to come on to show my friend what it is doing then i parked it and turned car off here are some readings i was getting: open loop left o2 sensor about 260 right was 0-1200 jumping around... closed loop both 02s were jumping from 100-900 ingition (v) 13.0 to 13.1 spark advance aroudn 20 MAP(v) 1.5ish Left BLM 129 Right BLM 133 A/F leaned yes TPS(v) 621 i think anyone have a clue what is going on here i also have the lake wood traction action bars.. i been told that they could be causing my solenoids to be going bad.. cuz it could be thoughin off the gemotry of my tranny n driveshaft n rear end... anyone ever hear of this |
| All times are GMT -5. The time now is 09:35 AM. |
