running without o2 sensors?
if my o2 sensors are bad and causing me to run rich enough to backfire, would the car be more driveable if they were unplugged.
i guess what im asking is which is better, no signal or bad signal?
If they are bad - replace them. Unhooking really can help as temporary solution - it will change the way PCM adjusts A/F ratio. It is a good idea to replace spark plugs together with O2's. If they are fouled during running rich - you will possibly damage your new O2's...
Originally posted by RE AND CHERYL
A bad O2 sensor dosn't put out a signal, thats why it's bad. When the sensor goes bad you are running straight off the base fuel map which is rich with out the O2 sensors to correct it. Just install new sensors.
they dont throw a code when connected, but do when they are not, yet it drives the same
