Running rich - throwing crank position sensor code?
Old Apr 11, 2006 | 11:52 PM
actionhank99's Avatar
A friend of mine just fitted a cc305 cam and ported heads to his lt1 , and now it runs rich. It will sometimes throw crank position sensor switch code, so we replaced that and the car still acts the same and still throws the code. Could there be a problem with how the pickup was put back in or maybe the opti???
Old Apr 12, 2006 | 03:29 AM
Zeueses 97 RamAir's Avatar
Re: Running rich - throwing crank position sensor code?
Make sure the cam is put in right, also there is a reluctor ring that goes on you might want to check that.
Old Apr 12, 2006 | 05:56 PM
96trans am's Avatar
I don't know if it would help the problem but you can tune out the crank position sensor. When you run a Double Roller you have to take out the reluctor ring and do away with the crank position sensor therefor I don't think its really needed.
Old Apr 12, 2006 | 06:08 PM
Dave89IROC's Avatar
crank sensor is used for misfire detection pnly on the LT1s with it(96/97), so I would just tune it out
did he get a tune with the cam/heads?
if not, he needs one
Old Apr 12, 2006 | 06:36 PM
96trans am's Avatar
you can tune it out on the 96/97's right?
Old Apr 12, 2006 | 07:34 PM
Dave89IROC's Avatar
yes
Old Apr 12, 2006 | 07:41 PM
96trans am's Avatar
I actually just put up a post for this because I need to know how to tune it out. Any idea how to do it?
Old Apr 12, 2006 | 07:44 PM
Dave89IROC's Avatar
just tune out/disable the related codes(P0300-P0308 for starters, plus the specific crank sensor codes)
Old Apr 12, 2006 | 10:32 PM
I have mine tuned out it does not hurt anything
HectorM52
Jul 30, 2017 11:46 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
Queens94z28
Dec 20, 2014 09:11 PM
Injuneer
Dec 15, 2014 09:36 AM
