CamaroZ28.Com Message Board
-   -   Rubber Elbow (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/rubber-elbow-387416/)
CHELOZ28 Aug 3, 2005 12:22 AM
Rubber Elbow
My elbow is all ripped up so instead of replacing it with the stock one, which one should I purchase. I want to know will I face any clearance issues as far as my Moroso cai, Granatelli MAF,and bbk 52mm throttle body. I have been looking at the Trick Flow elbow, what do u guys think?
SantaCruz163 Aug 3, 2005 12:39 AM
Re: Rubber Elbow
Trick Flow if you don't want a rubber one and have the extra $ to spend. If you don't care about it better rubber get a 1LE elbow without the hole for the donkeydong.
Netwrkengeer Aug 3, 2005 08:12 AM
Re: Rubber Elbow
I have a trick flow and a moroso CAI, it fit perfect with a little trimming of the rubber connector between the Elbow and MAF. Just used a razor it was easy.
2000GTP Aug 3, 2005 08:22 AM
Re: Rubber Elbow
Agreed, the Trickflow fits pretty well with a little trimming. I am using it along with my Moroso CAI.
CHELOZ28 Aug 3, 2005 10:22 AM
Re: Rubber Elbow
sweet thanks for the comments, Im going to go with the Trick Flow
matt65 Aug 3, 2005 11:23 AM
Re: Rubber Elbow
I have heard of these stock elbows tearing a lot.
How does it happen? :confused:
Bow94z Aug 3, 2005 11:32 AM
Re: Rubber Elbow
1le
Netwrkengeer Aug 3, 2005 12:33 PM
Re: Rubber Elbow
Heat... Taking them on and off.
CHELOZ28 Aug 3, 2005 01:43 PM
Re: Rubber Elbow
yeah mine is all torn up, just were you hook it up to the throttle body. You guys think this can cause some loss in power?
Netwrkengeer Aug 3, 2005 02:47 PM
Re: Rubber Elbow
more so on car with a MAF.
MRBoss429x Aug 3, 2005 04:04 PM
Re: Rubber Elbow
Not only a loss of power but it can cause misfire and stumbling problems. You might want to replace it soon if its in that bad of shape. $50ish for a 1le and $90ish for the trickflow if I recall correctly.
