CamaroZ28.Com Message Board
-   -   Rough idle after Intake install (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/rough-idle-after-intake-install-427744/)
SLeeper94Z Feb 3, 2006 03:59 PM
I just started my car up after doing the intake install and it has a very rough idle I have made sure its not any vacuum leaks... Only thing i didnt do was to lube up the O rings on the injectors... Is there Only one set of O rings on the Injectors? Im going to pull the fuel rail and see if the injectors are leaking
Any help will be appreciated thanks
SLeeper94Z Feb 3, 2006 04:05 PM
Re: Rough idle after Intake install
well I just pulled the Fuel rails and let injectors free hang, and turned the key on , No fuel came out, Do u think because i didnt lube up the o rings I could have a vacuum leak?
blkchevyz Feb 3, 2006 04:12 PM
the oil is more for easying it back in, if they are dry you could tear the o ring.
you could spray some carb cleaner around the injector port to see if it idle any differently, but ir really dont think thats your problem?
why did you pull it in the first place?
what gaskets did you use? you didnt use that cork from and rear gasket did you?
triple check your connection to the injectors, and everything to make sure they are where there suppose to be... a crossed injector would cause some issue.
Z28LT1_Just_Nasty Feb 3, 2006 05:44 PM
Check the MAF connections, same thing happened to me after I installed my trickflow elbow. Turned out I didnt have it "completely" connected. Worth a try.
OBE1 95Z28 Feb 3, 2006 07:45 PM
Verify you reconnected all of the vacuum lines (EGR, FPR, Brake booster, HVAC system line, PCV, EVAP line to TB).
1racerdude Feb 3, 2006 08:00 PM
Probably a vacuum leak somewhere as has been said. Carb or choke cleaner will tell ya. Lube "O" rings with white lube/105 grease/Lythiam grease and get it running and spray around hose connections,injectors,intake flange,ect. Listen for any hissing,sucking,whistleing noise.
