roller rockers
Old Apr 19, 2006 | 03:08 PM
riodealz28's Avatar
roller rockers
i puting a new set of 1.6 roller rockers what els do i need for the instalation what kind of springs ect.
Old Apr 19, 2006 | 03:16 PM
seawolf06's Avatar
Re: roller rockers
Springs are going to be determined by the cam you intend to run. If you don't intend to run anything other than a stock or LT4 hotcam, you can use the LT4 springs and should just get the LT4 hotcam kit from summit or somewhere. Otherwise, it depends on application. You'll also probably need some new gaskets. I'm going to be doing this soon as well and putting a list together. The search function is your friend.
Old Apr 19, 2006 | 03:23 PM
BlackScreaminMachine's Avatar
Re: roller rockers
but if you have ANY intentions of anything bigger than a hotcam do a spring upgrade that can take up to 0.600" lift, you will never know the future and to do a valve spring swap x2 would suck.
Comp cam has a great selection of rockers, if not going to a crazy set up, self aligning rockes with a 3/8" stud would be fine. ARP studs prefered.
Old Apr 19, 2006 | 04:06 PM
riodealz28's Avatar
Re: roller rockers
i think im going with this cam but later in the future
CCA-07-467 --- 230@ .576/ 236@ .570 (1.5RR)--- 113 LSA
Old Apr 19, 2006 | 04:11 PM
riodealz28's Avatar
Re: roller rockers
never mind i just want some simple cheap springs that would work for right now ill change them later with the cam setup but can any body just give me a part# of some good springs cuz i already posted this on 2 other webs ite and no part #'s
Old Apr 19, 2006 | 04:15 PM
Re: roller rockers
thats a big cam there, .570" with a 1.5!!m thats a .608 with a 1.6 rocker, so I would say comp cam 918 springs, I use those with my cam good to up to 600" Mine is a little higher and no issues.
Old Apr 19, 2006 | 04:31 PM
riodealz28's Avatar
Re: roller rockers
so i can use the 918's with just the rr's and stock cam for now ? so that's all i need just springs no lifters or push rods ?
Old Apr 19, 2006 | 04:35 PM
Re: roller rockers
on stock heads, 7.200" pushrod, the applicable retainers and locks will be needed, steel is cheaper than Ti.
I am not sure about the shims or locators, i didnt do my spring swap. But installed height should be checked in each spring
Old Apr 19, 2006 | 04:43 PM
riodealz28's Avatar
Re: roller rockers
can u give me part #'s of the parts u just said
Old Apr 19, 2006 | 05:32 PM
Re: roller rockers
HIGH PERFORMANCE GM LS1 VALVE SPRINGS
PART #26918-16 233.54
STEEL RETAINER FOR 26915 & 26918 SPRINGS
PART #774-16 $66.56
I dont have the lock part number ill ahve to look if anyone else has it, please post
Old Apr 20, 2006 | 01:34 AM
riodealz28's Avatar
Re: roller rockers
thanks
13qtr
Oct 28, 2016 08:11 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
