Roller Rockers
Old Feb 3, 2004 | 09:22 AM
DansZs's Avatar
Roller Rockers
I was reading through some of the threads to try and determine which 1.6 roller rockers I should buy and I read where it really depends on your set up. I am going to have to change my intake manifold gasket in the near future and I should have enough money to do 1.6 rr and springs. The problem is, when reading through so many of the posts I wasn't sure which RR/springs would be good for me for my future plans. I eventually plan to get a set of AFR heads 190s or 195s and a CC 230/236. What RRs and springs would best compliment this setup that I can use with my stock heads and cam until I can save up to get the new heads and cam? Also, when I was reading through the posts I never noticed whether I'd need to get a computer program to account for the 1.6 RRs. BTW in the past I had considered getting the crane gold RRs. Would these be any good? Thanks for your help!
Also, would I need retainers or seats for the new springs?
Old Feb 3, 2004 | 01:03 PM
Spinner's Avatar
I wouldnt buy the crane, or GMPP (by crane), or scorpion rockers all because they're made of aluminum. Aluminum fatigues, and will eventually break. Steel wont. I'll stick with comp pro-magnums.
Old Feb 3, 2004 | 01:08 PM
SVT Killer LV's Avatar
real men use comp pro magnums
Old Feb 3, 2004 | 04:16 PM
DansZs's Avatar
Thumbs up
OK, the cc pro magnum's were my second choice so I'll definately go with them. What springs should I use and what about the retainers, seats, and computer programming?
Thanks again for your input!
Daniel
Old Feb 3, 2004 | 04:24 PM
Spinner's Avatar
combination motorsports has an excellent spring/retainer/lock package for a good price. www.cmotorsports.com
You'll want the 612 spring kit. Comes with springs that are good to .600 lift, retainers, and locks.
You might as well get the 7/16 studs and 7/16 rockers instead of the 5/8. Get the Non Self Aligning ones, and then give Jason Cromer a call and get some GMPP guideplates.
Old Feb 4, 2004 | 06:48 PM
DansZs's Avatar
OK, but will these still work with my stock computer program and the stock valve covers?
Thanks for the input
Daniel
Old Feb 4, 2004 | 07:17 PM
Daniel
Stock computer program, ok.
You will need to do some clearancing inside the valve covers for the Pro Mags to clear.
Some of the best pics I have found about modifying the stock covers are on the bottom of this B-body page.
13qtr
Oct 28, 2016 08:11 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
