Roller Rocker clearance help
Will the 55-87 1.5 Crane Gold's fit under centerbolt valve covers with enough clearancing of the valve covers? thanks for the help guys.
Better check with the vendor on this. Not too many on here stick with stock lift of 1.5. I would guess that if 1.6s clear so would the 1.5s. Several on here merely bend some metal under the covers to accommodate some RRs.JMHO:cool:
Yeah, do a search, the process involved in modifying the valve covers to accomodate different rockers is pretty simple. I've even seen modified factory valve covers for sale on the forums here several times as well.
good deal, thanks guys
