Rods..dots point in or out?? HELP!
Old Aug 28, 2004 | 04:59 PM
5.7LT1Formula's Avatar
ok...i just got my rods and pistons hung and started to put things together... i noticed when i took my motor apart for the rebuild that the dots on the rods and caps were facing each other...after i had my rods redone and my new Keith Blacks put on and i noticed when i put them in the dots were facing away from each other..
everything looks good on the crank etc...but did the machine shop screw up again??..(last time they put in a defective cam bearing but made it right)
Is this the right way? is it ok the way it is?
THANKS!
Old Aug 28, 2004 | 05:28 PM
Re: Rods..dots point in or out?? HELP!
ttt
Old Aug 28, 2004 | 05:46 PM
http://web.camaross.com/forums/showthread.php?t=5485
Easy to tell on stock rods, but don't know about the rods you have.
Old Aug 28, 2004 | 05:48 PM
these are stock rods. there is one dot on the rod and one on the cap. these are not the "ridge rods" thats have a beefer bottom cap to them.
Old Aug 28, 2004 | 05:59 PM
Don't know if this picture will help, but my stock rods/caps have a curved and a flat side. The flat side faces the main bearings. You can see some dots in the pic on the one being tightened (if that is what you mean).
Old Aug 28, 2004 | 06:01 PM
shoebox your a life saver! everything looks right...i'm getting to the point where i just want to drive my car before snowflies and other peoples screw-ups are slowing me down.
Thanks again!
-Ryan
Old Aug 28, 2004 | 07:45 PM
marshall93z's Avatar
shoebox, whats up with the wire on the bolt?
Old Aug 28, 2004 | 09:54 PM
It's part of the torque/angle meter. It keeps it still while you are using it.
Old Aug 29, 2004 | 11:07 AM
oh ok, i was just curious when i saw the red handle on it...was thinking about electricity!
93 RedBird
Nov 15, 2015 08:24 AM
68camaroboltz
Oct 5, 2015 01:46 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
alliance12364
Sep 17, 2015 08:43 AM
