Rocker help needed FAST!!!!!!!!
Are these going to work with my LT1 heads?
http://store.summitracing.com/egnsea...N=115&x=34&y=6
I ordered them through my local shop because I saw somewhere they would but according to summit they only work on motors up to 1986. Do they state this just because they are NSA rockers?
Pushrod link
http://store.summitracing.com/partde...6&autoview=sku
Don't forget you'll need guideplates aswell..
I'd be a little leary about buying those. A person I knew from another board bought something similar to those (NSA) and because the rocker body was so huge they bottomed out on the hex part of the studs, pulled two studs out of the heads, all the rockers were gouged where it made contact on the studs, bent the pushrods from the two studs that were pulled out and most of the other pushrods were eaten from being pushed into the guideplates. He didn't know a whole lot and had a shop install them who of course didn't know WTF they were doing.
If you are going to go with those make sure to check the rocker body to stud clearence.
Good luck with the install..
