CamaroZ28.Com Message Board
-   -   rocker arms?? (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/rocker-arms-381362/)
lt1street Jul 10, 2005 03:53 PM
rocker arms??
Does the lt1 use the standerd or different rollar rocker then a regular 350 or is it the same. Also valve spring same or different???? Looking though a summit or jegs you some time see lt1 rollar rocker then some time you dont see any listing. woundering if it just a money maker or do the really have a different setup?
ProjectJ Jul 11, 2005 07:07 AM
Re: rocker arms??
The LT1 requires that you use self-aligning rockers (unless you modify the heads to use screw in studs and guideplates).
NBred94 Jul 11, 2005 07:13 AM
Re: rocker arms??
Aluminum head LT1's do not require any modification to use screw in studs. If you decide to use NSA (non-self aligning) rockers, you will have to use guideplates as mentioned above, but the stock rocker arm studs are screw-in type. ARP makes longer (for the guideplates) replacement screw-in type studs specifically for our application.
If you go to Thunder Racing's site and search by vehicle, you can see all of the specific stuff available for the LT1. I just swapped out my rockers a couple of weeks ago.
rskrause Jul 11, 2005 08:22 AM
Re: rocker arms??
If you are thinking of aluminum roller rockers, you need to get a model designated to use with center bolt valve covers, they are narrower than the rockers made for perimeter bolt covers.
Rich
